Custom Settings
Where are the Custom Settings stored? I think I am deleting the file/settings as a result of a registry cleaner I use.
A few reg cleaners do clean them. They are stored at HKEY_CURRENT_USER\Software\VB and VBA Program Settings\CCleaner\Options
If you use RegSeeker you can get a custom exclude.ini HERE
