Current Progress Stuck at 0
I'm having an issue trying to recover some files off a hard drive camcorder. It finds the files after a couple of seconds and they have status of Excellent. When I click on Recover, it just shows the "current progress 0%" that never moves and "calculating time left" never changes.
Log is below: (I can't get a dump file. I get access denied.)
[2010-12-14 22:26:31] [iNFO ] Recuva v1.38.504
[2010-12-14 22:26:31] [iNFO ] System Info: MS Windows Vista Ultimate SP2, Intel Pentium 4 CPU 2.80GHz, 2.0GB RAM, RDPDD Chained DD
[2010-12-14 22:26:34] [iNFO ] No update available
[2010-12-14 22:26:58] [iNFO ] Boot sector:
61iQICAgICAgICAAAkAgAAIAAAAA+AAAPwD/AD8AAAA3CXwD4BsAAAAAAAACAAAAAQAGAAAAAAAA
AAAAAAAAAIAAKV1sAABFVkVSSU9fSEREIEZBVDMyICAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAVao=
[2010-12-14 22:26:58] [iNFO ] FS type detected by BPB parameters, OEM name is unknown.
[2010-12-14 22:26:58] [iNFO ] Processing folders from 2
[2010-12-14 22:26:58] [iNFO ] Analyzing damage
[2010-12-14 22:26:58] [iNFO ] 10 deleted files, 45 filesystem objects
[2010-12-14 22:26:58] [iNFO ] Processing deleted emails
[2010-12-14 22:26:58] [iNFO ] Processing recycle bin
This problem has been reported before, unfortunately there doesn't appear to be a fix for this behaviour.
You could try some alternates such as the free version of Handy Recovery or the crippleware version of DiskDigger.
Richard S.
Thanks Richard. I saw some posted earlier in the year and didn't know if any progress had been made on it. Thanks for the suggestions. I got several files back with PhotoRec, but haven't had luck with the other file that I need.
Thanks for the log. We'll have a look at this :)
