Crap Cleaner causes PC to shutdown [solved]
It has happened twice now - when I run crap cleaner my Windows 10 PC shuts down -any1 have any ideas. I have been using the program for over 10 years without any problem.
17 minutes ago, John Roberts59 said:
Have a quick check to make sure you havent got ''Shut down after a Custom Clean'' ticked in CCleaner Settings......Advanced.
Have you inadvertently told CCleaner to shudown the computer after a clean? (Edit- Hazelnut beat me by seconds).
Yes just unticked "Shutdown after clean" and no further problems. I can't remember seeing the option b4 -tx ?
