Corsair iCUEs sorftware
Hello folks,
I'm having the issue that Corsairs iCUE software is not running due to some missing dll files, which I think has happened after switching over to windows 11. It is not allowing me to uninstall the program, which also means I cannot reinstall the software. I have installed CCleaner in order to attempt to remove it, however it is also unable to find the iCUE software in order to uninstall it.
I'm really at a loose end here. Please help if you can! TIA
CCleaner only runs the same uninstaller as Windows, so if Windows won't do it then CCleaner won't either.
Have you tried just reinstalling it without uninstalling first?
Many softwares will let you do that.
Here are a few things to try and get your iCUE working: https://www.partitionwizard.com/partitionmanager/icue-not-opening.html
Other than that you could try try asking on their own forum: https://forum.corsair.com/
