Hi guys
When I Log In to say> "Pirifom Forums" I always enter my (user-name & password) manually.
I herd that you could "copy & past" user-names & passwords into the required boxes from a notepad text file? would this be safe to do?
Hi guys
Hi guysWhen I Log In to say> "Pirifom Forums" I always enter my (user-name & password) manually.
Do you want them stored anywhere other than in the "little gray cells"?
davey
Yeah but it would be quicker to just type them than to have to open a notepad file and then copy the pass and then the username. Why not just have whatever browser you use save the login info, or just have CCleaner not remove its cookie(what I do).
I think because for quite a few people logging into this forum has to be done each time. I am one of them.
I have tried everything I know and still have to sign in.
It's the only forum I have to do this with
That's strange.I think because for quite a few people logging into this forum has to be done each time. I am one of them.
I'm automatically logged in every time unless I delete the Piriform cookie.
I'm able to automatically log in every time to all forums I watch as long as I don't clear their cookies.
Same here Kenny, can login in elsewhere. I have deleted the cookie, revisited, ect etc. I have even tried shouting at it!!
may try again later.
This site is completely unpredictable for me.
Usually I'm not auto logged in, and that's the way I prefer it, although the wand is active in Opera, and the username/password are already there to enter with Firefox.
Sometimes I'm logged straight in, and my immediate thought is I mustn't have logged out, but the "your last visit" time and date seems to confirm that I had logged out. I've tried to find a way to make this consistent, but still looking.
CCleaner keeps my wanted cookies. I'm always logged in here. Some sites change/update their cookies on a daily/weekly/monthly basis. I can't control that.
You might find if you "copy+past" you will have great difficulty. Try "copy+paste" instead that might work
I never have a problem with this forum remembering my cookies. I am always automatically logged in. The only place I have an issue is with the FF addons page. I am always logged out on that page even though I do not delete the cookies and check the box to remember me on the site. I have that problem on all browsers on all machines with that site.
I used to have the same problem hazelnut, but I found a way around this login problem. Just chose a forum, in my case I chose "Lounge"and save page as a bookmark (as a bookmark in my case because I use Firefox). Now every time click on the bookmark it takes me directly to the Lounge and I am logged in. Try it.
I'm still trying razz, I don't like to give in.
If it all fails, I'll use your workaround
OK a little "typo"
OK a little "typo"
I thought it was a small shout-out to the online meme of "Copypasta". I need to get out more.
OK help needed
I'm using Firefox 3 and would appreciate some guidance with "settings" for Firefox.
Below are the current settings I have.
Tools> Options> Privacy> Private Data> [YES]> Always clear my private data when I close Firefox
Settings>
[YES] Browsing History
[YES] Download History
[YES] Saved Form and Search History
[YES] Cache
[YES] Cookies
[YES] Offline Website Data
[YES] Saved Passwords
[YES] Authenticated Sessions
...I have even tried shouting at it!! ...
Have you tried getting up for a cup of coffee and then returning?
I shouted in a very calm way
(still didn't work)
OK help neededI'm using Firefox 3 and would appreciate some guidance with "settings" for Firefox.
Settings>
[YES] Cache
[YES] Cookies
You have save psswords set to yes thats fine. Now when you log in to a site you should get prompted by FF to save the login info select yes. The login info will now be remebered so even if you come to the forum and you are logged out the login info will be filled in for you and all you have to do is press "login".
For Tools> Options> Privacy> Private Data> if you select yes make sure you have not selected to have saved passwords deleted.
Hey Anthony , I don't have passwords set to yes (save)
I have all settings set to [yes] for> (Always clear my private data when I close Firefox)
I need to know how to adjust my settings in "Firefox" to allow "cookies" & whatever is needed... so as I don't need to manually enter my user-name & password for "Piriform Forums" and other sites that I trust.
I realize that CCleaner is going to have an impact' with regards to what it will clean when it is run... so I also need to know how to configure CCleaner as well
Sorry' but I'm a bit confused and worried about making changes with the settings... dose keeping "history" come into this equation?
I'm no expert , and as always' any helpful replies and advice is greatly appreciated.
Hey Anthony, I don't have passwords set to yes (save)
I'm no expert
OK I mis read the post than. I see what you mean know.
Even so what I said still goes if you want to keep your login info for the sites.
You need to go into FF settings and allow cookies. Than you need to set the "Clear Private Data" to not delete cookies. You can also set FF to save Passwords so even if you delete a cookies to a site you want to be logged into the login info will be automatically filled in and all you do is click login or OK on the site. Lastly go into CCleaner options and find the "cookies" feature. Once there move the cookies from the sites you want to keep from the "cookies to delete" to "cookies to keep". Now when you run CCleaner it will not clean the cookies you moved.
Hey Anthony
Thanks for all the info , I was thinking along those lines, but I wasn't 100% sure.
I just needed some backup info..."guidance"
Thanks again
