Cookies to keep
when trying to pick cookies to keep from a long list, it is very time consuming. Instead of sorting the whole list alphabetically, why not sort by most recently created? It might be easier to pick new ones that I may want to keep.
+1 (Or better last accessed)
Last accessed would be great...I forgot that it is tracked in windows (you can see it in file/properties)
Not sure whether to open a new topic, or add to an existing topic on the Cookies to Keep list :
1/ it is not clear from the help file whether, in order to keep all cookies from sub-domains ("members . mydomain . org") and sub-directores ( "www . mydomain . org / guests" ) of a domain, the entry in the Cookies to Keep list should be a/ " mydomain.org " or b/ " *.mydomain.org ".
2/ irrespective whether a/ or b/ above were the correct format to set a wildcard for the whole domain : a one-click way to change any cookie to the correct wildcard format would be appreciated.
This can be in the right-click menu adjacent to "edit", and the option to amend multiple domain entries in one go would be a nice addition.
Looking forward!
Used the edit option to see what it allows to do, and how revisions are noted.
