Cookies problems with CCleaner V 2.12.256 & V2.12.660
I use Vista Premium 32. My browsers are IE7 and Mozilla. I have used CCleaner for a number of years and this is the first time I have had a problem. Yesterday I was told there was a new version, which I downloaded and I now notice that certain cookies I want deleted stay. On going back to the previous version everything works OK.
I have read through the various threads on this subject and have completely uninstalled, downloaded again reinstalled and still get the same problem so I have gone back to the previous version. Is there any suggestions on how to overcome this problem?
David
It would help if you could list which cookies they are.
Are the cookies that dont get removed the same for both browsers? For example if a cookie from piriform dosent get removed for IE, does it also not get removed from Moz?
David
I have got the same problem and also unable to ?rase 10 cookies with this new version i.e V2.12.651 so since nobody can help i went back to the former version i.e V2.11.636 and i have no more problem. Afraid i will wait for another new version before changing.
I do not have either browser on when I use CCleaner. I have reverted to the previous version at the moment so my unwanted cookies are now removed, I have tried on several occasions to re install but this seems a waste of time as it never works, as I now do not have the cookies displayed I cannot remember all of them I do know that double click is always there.
David
People are trying to help, but you're popping up in three different topics, instead of sticking with at least one and providing information which may result in your problem being fixed.
http://forum.piriform.com/index.php?s=&amp...st&p=116259
Again having problem with this new version V2.12.660 (same problem with former one V2.12.651) unable delete 10 cookies which are as follows :
apmebf.com
doubleclick.net
espaceclient2.orange.fr
iapref.orange.fr
mediaplex.com
mobile.orange.fr
orange.fr
partirpascher.com
sdc.francetelecom.com
www.orange.fr
I have MS Windows XP SP3 and using Internet Explorer 7 (IE7)
Whether someone can help me i will appreciate very much and in waiting i will rush and return to the former one version which is working fine : V2.11.636.
Many thanks and best regards
Andr?
David
You reverted to a previous version of CC and cant provide any information about the problem. What did you expect to get out of this thread? Unless someone can provide some real info about the problem and how to reproduce it, I dont see it being resolved.
I've tried several times and visiting an array of sites and cant reproduce the problem.
OS: Vista Busienss 32 SP1 (Elevated Admin Acct)
Security: PCTools Threatfire. (WinDef and Firewall disabled)
CC: 2.12.651 & 2.12.660, saving settings to INI and using Normal delete method
Browsers: IE7 and IE8 Beta 2 (via loading drive images)
Bonjour, voici le genre de cookies, here is an example of cookies that cannot be removed :
apmebf.com
doubleclick.net
iapref.orange.fr
mediaplex.com
mobile.orange.fr
orange.fr
partirpascher.com
www.orange.fr
d?d?, I prefer not to let those cookies onto my system in the first place by using a HOSTS file.
HOSTS files I use:
http://www.mvps.org/winhelp2002/hosts.htm
http://hosts-file.net/?s=Download
Managed with HostsMan and I use its HostsServer proxy to speed up browsing:
http://www.abelhadigital.com
HOSTS files I use:
That's a good point Kenny.
But the poster is wanting to know why CCleaner is not deleting those cookies now.
If their ISP is one of:
iapref.orange.fr
mobile.orange.fr
orange.fr
partirpascher.com
then the ISP is placing the cookies and they will be deposited as fast as they are deleted so no matter how much cleaning is done they obviously want to keep track of things.
How many Google cookies get deposited but they are deleted every time CCleaner runs.
HOSTS files I use:
If i understand well, i could not never clear these 10 cookies? How is it with v2. 11.636 they do not appear?
Sorry again for my English ! (i al French)
Hello dede,
Thank you for reporting this problem.
In order to fix this it will help us to have the following information.
Just fill in the answers next to or below the questions?
CCleaner version ?
What Language did you request at install,if any?
OS,edition ,32bit or 64bit and version ?
Browsers and ver.?
Security software and ver?
Provide a list of your CCleaner.ini file.( Tick option for Save settings to INI file at Options > Advanced then close CCleaner.This file will be created in C:\Program Files\CCleaner folder.)
Edit out any Personal info with XXXs Do not delete anything, please.
Are you using a winapp2.ini file?
Answer "Yes" if you do and please explain its contents or provide a brief listing.Otherwise answer "No".
Best wishes and thank you for your information,
:) davey
The CCleaner Guide is your first source of information.
http://www.ccleanerbeginnersguide.com/ CCleaner Beginner's Guide.com
Bookmark & save to Favorites
David
Hi DeeBees,
Please help us also.
In oder fix this it will help us to have the following information.
CCleaner version ?
Browsers and ver.?
:) davey
Hello dede,
CCleaner version ?
Browsers and ver.?
:) davey
Hi Davey, many thanks for your answer. I am using Windows XP SP3; Interl?Pentium 4 CPU 3,20 GHZ, 503MB RAM; Intel 82865G Graphics Controller and using IE7 (Internet Explorer 7. Problems occurred when using CCleaner version V2.12.651 and also with the latest one V2.12.660 so i desinstalled these versions and took the former one i.e V2.11.636 which is working very fine and no more cookies. If i am reloading V2.12.660 problem is still in effect. I forgot, i am on 32bit.
Thank you again and best regards.
Andr?
Hi dede,
I've tried and just cannot reproduce the problem. That doesn't mean to say I don't believe it's happening, it just makes it that bit harder to find out why.
I have XP with SP3, and using IE7, the screenshots are after visiting a few of the sites you have cookies from, and then closing down the browser.
CCleaner Analyze: Version 2.12.651.
CCleaner after cleaning:
This is a strange one.
PLEASE NOTE:
I've merged dede's other topic with this one. Problem still occurring with CC Version 2.12.660.
Post number 7 above.
PLEASE NOTE:
Regarding cookies, i tried to reinstall V2.12.660 and looking at cookies here is a list that i can see :
apmebf.com
doubleclic.net
iapref.orange.fr
mediaplex.com
mobile.orange.fr
orange.fr
partirpascher.com
www.orange.fr
What is curious is that when i uninstall the very latest version and coming back to V2.11.636 there is no more cookies to be deleted so i can tell now that there is a bug somwhere however where ?
Unless i definitely desinstall CCleaner and take "Glaries" or "TuneUp Utilities".
Anyway whether someone can help he will be welcome. Many thanks again and best regards
Andr?
Having reported the same problem, I tried moving the "ghost" cookies to the Keep column. Ran Cleaner. Then moved the "ghost" cookies back to the Remove column. But as always they never were removed. As noted the problem does not happen with 2.11.
XP\SP3 Firefox 3 2.12.660
