I upgraded CCleaner Professional to Version 27.11214 and now no cookies appear in the left hand pane even though cookies are being installed on my computer. Currently there is no way to save a cookie to move it to the right pane since it they don't appear in the left pane. My subscription expires in 4 weeks and unless this bug is resolved by then I will not renew my subscription because the program is unless if you don't have the ability to save your cookies for a particular website.
Can you say what particular cookies are involved here?
PS. Windows itself can/will load cookies even if you don't go anywhere near a browser.
27 minutes ago, hazelnut said:<div class="ipsQuote_contents"> <p> What operating system are you both using? </p> <p> If you do a clean install of the latest CCleaner does it still happen ? </p> <p> (don't forget to make a note of your licence number before uninstall.) </p> </div>
I am using Windows 11. Uninstalled and reinstalled the program but the issue still remains. This all started when CCleaner updated to the latest version 6.27.11214. So obviously this latest version has a bug. Guess I will have to wait until the next version comes out to see if the problem gets corrected. If not, then I will permanently delete the program.
18 minutes ago, hazelnut said:<div class="ipsQuote_contents"> <p> What operating system are you both using? </p> <p> If you do a clean install of the latest CCleaner does it still happen ? </p> <p> (don't forget to make a note of your licence number before uninstall.) </p> </div>
I have the same problem. It all started with the latest CCleaner update.
