Cookies not cleaned
Never had this happen before. It did keep my "To keep Cookies" just fine but left about 20 in the "Cookies to Delete". I'm assuming they're Flash cookies?
I'm still on CCleaner version 4.02
w7 64 bit
IE9 just updated a couple days ago.
I suppose I should update CCleaner, am quite behind. So, if I do, will the update still save my Keep cookies? iirc, I had quite a time trying to get them set correctly.
Thanks a bunch,
grits
Highlight one of the cookies, at the bottom of ccleaner you will see a symbol, describe it.
yup, all the leftovers are Flash.
Check to make sure Adobe flash is checked off in the applications tab
