I understood from your first post that CCleaner found 8 cookies to delete,
but it was unable to delete them,
and furthermore you were unable to see them for yourself.
Now you are saying that you can see them and have identified their specific locations,
and CCleaner can also see them but is unable to delete them,
but you can not only see them you can also delete them.
I do not know how to understand this.
I suggest you try purging the entire infestation of Adobe trash.
I do not know if it is relevant to your needs,
but this is how I handle the two FLASH paths you have now specified.
Years ago I zapped Adobe trash at the roots at each User profile via CCleaner > Options > Include.
When I found WinApp2.ini understood Environmental Variables I only took the axe to the pair of roots in %APPDATA%.
My corresponding entry is no
[userProfile#]
LangSecRef=3024
DetectFile=%USERPROFILE%
Default=False
FileKey1=%APPDATA%\Adobe\Flash Player\|*.*|RECURSE
FileKey2=%APPDATA%\Macromedia\Flash Player\|*.*|RECURSE
Every time I use the computer any Adobe trash has to recreate its habitat before it can start working against my interests.
I understand that the latest versions of CCleaner will now allow you to use CCleaner > Options > Include,
and then you can edit the CCleaner.ini file to replace one specific User Profile Application Data path with %APPDATA%
