I have not as yet downloaded Ccleaner ... before I do I wanted to know if it is compatable with McAfee Security Center? ... Thanks
Yep - no problems - no conflicts that I know of.
AJ
AJ
Thank you for your help ... will give CCleaner a try ... I used to have SpyBot, however uninstalled it when I got McAfee ... how do you compare CCleaner to SpyBot ... last question, I promise ... thanks
they all have different functions
McAfee = Antivirus
SpyBot = Antispyware (different to viruses)
CCleaner = junk cleaner, cleans temporary files and program leftovers.
so you could have all three if you wanted to
McAfee = Antivirus
Thanks for your help ... I appreciate it ... I will say, though, that when I had Norton my SpyBot seemed to conflict with it ... I received free McAfee and "ass"umed I might have the same problem so uninstalled Spybot ... thanks again for the good tip ...
