cmd question
Hello there,
I have a program at work I use that is run through the command prompt, and this program displays some plots/graphs in the full screen of the computer. Once the program is completed, the command prompt is stuck in full screen mode. Is there anyway to get it to go back to normal window display mode after you enter full screen mode. currently we have to use the windows key to get out, then go in and manually select that we want the window display. Thankx a lot for any help.
also, changing the program itself is not an option since it is proprietary software...and also of note, this only effects winXP versions, works normal on win98.
thankx
You can use Alt-Enter to get into and out of full screen mode.
PERFECT!
my boss is so impressed with my 'knowledge' of computers, so I told him about a little thinktank I know about called Ccleaner Forums. Thankx again
nH
PERFECT!
Glad I could help. Hopefully, you can get a raise now...:)
