cleaning subfolders
I really love CCleaner, it just makes the computer work so much better/faster :D
But I have now come to a point where it can't help me, cuz I can't add whole drives or subfoldes and look for etc. *.bak and then remove it.
Take World of Warcraft which I play, it has a folder called WTF, where all user files and configurations are saved.
Some are saved under the user (login name) other for each character and look like this
WTF
|+USER1
| | - *.old
| | - *.bak
| |+ Charater1
| | | - *.old
| | | - *.bak
| |+ Charater2
| | | - *.old
| | | - *.bak
| |+ Charater3
| | | - *.old
| | | - *.bak
|+USER2
| | - *.old
| | - *.bak
| |+ Charater1
| | | - *.old
| | | - *.bak
| |+ Charater2
| | | - *.old
| | | - *.bak
| |+ Charater3
| | | - *.old
| | | - *.bak
So I have to add etc. D:\WoW\WTF\*.old and D:\WoW\WTF\*.bak and be able to go through all subfolders
And before you write that I can make a batch file... yes I could do that, I could also write a program to do it,
but it would be nice just to have one program to do it all :D
Another member who had a World Of Warcraft question. This maybe could be of interest to you:
http://forum.piriform.com/index.php?showtopic=20612
EDIT: Welcome to the forum by the way.
Not really a help, but thanks for telling. This deletes all files in the folders, which is a no go, as only need backups to be gone, not the configuration files.
What I tried as a test with Analyse: D:\WoW\WTF*.*|*.old, i found that nothing is processed after the |(pipe)
Thanks :D
