Cleaning Selected Directories
I download some transaction data, usually into one specific directory, for use by accounting programs. Once used, the downloads are no longer needed. It would be really helpful if users could specify a directory(s) in CCleaner to clean (i.e., erase and wipe anything in the directory). I try to remember to do this but don't always and it would be just another step in preventing someone from getting information they weren't supposed to have in the first place.
Thanks for a great program.
Never mind. I found it. Thanks.
Thanks for letting us know. :)
Although, this doesn't seem to work in Vista/7... At least, not without a lot of painful .ini editing. Sigh. So, you must be using XP?
Great to know you found it & that it is working! Works great in XP!
