cleaning progress bar
How long does cleaning take? It's been going for 2 hours and the progress bar is still 5%. The first 2 items on the list to be cleaned are temp files and cookies. It's now doing history. How much longer?
Firstly, are you using the "Wipe Free Space" function and secondly, what are your system specs. If you don't know, try Speccy.
