Been a user of CCleaner for a while now. No real problems until suddenly today, after analyzing then choosing the clean, the window just automatically shuts.
It does not do this with any other functions, just when attempting to clean, the window shuts without any input or progress after clicking clean.
The CCleaner process still exists on the task bar, but that's all there is. It doesn't actually clean video data, empty the recycle bin, etc.
What antivirus do you use, this has similarities as a bug which is caused by antivirus.
I have the same problem. When I chose the Clean, the software shuts. I use Kaspersky anti virus. I stopped the antivirus, but the Ccleaner doen't work.
That's what I thought. Kaspersky has a current bug that's doing this. Make sure you've updated Kaspersky (I believe it's to 19 (g) but I don't use Kaspersky myself)
You'll find the rest of the solution here
