Cleaning problem
Hello there, I was using this program CCleaner version 1.33.382 and was trailing eEye program Blink Personal261
here - http://www.eeye.com/html/Products/Blink/personal
and on cleaning, it caused a mini dump. Since though, installing after removing and cleaning
the issue returns, even though I did remove and clean Blink off the system. I have a copy of the dump, and the team at eEye has it already, due to it was related to the fail of their driver. It is listed here, but I can send them to you too.
http://www.dslreports.com/forum/remark,17101611
On checking which checked box caused the issue, it seems the "recent documents" box is when it starts.
I have notified the team at eEye about this link as well. Hopefully between you both you can reproduce it, and fix it.
