I couldn?t find the check box in the Cleaner v120540 to delete MRU?s. Could MRU?s be listed in the Cleaner under some other name?
I couldn't find the check box in the Cleaner v120540 to delete MRU's. Could MRU's be listed in the Cleaner under some other name?
Hi alexander33
CCleaner v2.03.532 is the latest version to date.
The Beginner's Guide has helpful info.
Other Explorer MRUsMRUs (Most Recently Used) are lists within windows and in applications that maintain a list of the last few (normally 4 to 8) opened documents. It is normally located on the File menu of the application. This option clears a range of minor lists within Windows, including common dialogs, network drives and DirectX applications.
