Hello
since 3.01.1327, I have no cleaning of Internet Explorer files and index.dat !
thanks for your answer...
Hello
Please can you say which version of Windows you are using.
Welcome to the forum
XP home
Any idea ? !
Well ! I will stay with 3.0.0.1310
and thanks to the 140 readers
I am sorry, but I missed it.
Where is the rule that I may read a topic but must then contribute either with help or an apology for my inability.
Alan
um maybe you don't realize but it is holiday season and thus many of us helpers are busy. Also you give no information
What does this mean
I don't have this issue. Please note that as index.dat is not vacuming and not removing the file (I believe) it will not be listed as a file cleaned but it should be deleting the data in it
EDIT: Removed incorrect, wrongly placed not which must have caused confusion in this thread
This has been raised in other topics. It seems that the index.dat files are not listed anywhere in either analysis or clean, and there's some confusion whether the important ones are cleaned (CC never cleaned all index.dat files). Documentation on this is zilch, so we're still in the dark.
Sorry ,I'm just a french man with a school english language !
Why in 3.0.0.1310 they appear in the right window and not after... ? !!!
Si seulement nous savions.
Because, as I just stated above, the dat files themselves are no longer deleted just emptied (think of it akin to the reg entries that are removed but not listed in analyis or clean)
Have you this (Index.dat) or not with 3.02.1343 (right window) ?
edit at 21:45 fr :
Thanks for reading and I don't annoy you longer !
Not resolved
edit at 21:45 fr :
Not resolved
I don't understand why you say it is not resolved?
I told you the files themselves are no longer deleted (except for privacIE, IECompatcache and IEtldCache) thus it'll say zero files
I also don't understand why, when yesterday the last post you made said "canceled" which I took to mean that you actually don't have the issue, you post such a rude response and the open a new thread with just a link to this thread.
please read my responses above
I carefully laid out to you that the indexes are now emptied
and
on top of all that, many of the dat files previously removed by the (all-incompassing and confusingly vaugue) index.dat check box are now found in IE History clean
I have no IE cleaning !!!
The end for me but I am disappointed
Well at least you didn't have to find an English dictionary to discover the meaning of obtuse............
Since no one seems to be able to help OP, perhaps the thread should be closed.
agreed, but only because it is becoming insulting and the original poster is not giving enough information to allow us to give aid (and has twice stated that they give up on recieving an answer)
Based on a conversation I had with the Original poster I have reopened this topic. Please be aware that rudness and insults will NOT be tolerated. This includes posts by the members as well as by the original poster.
Just because someone speaks a different language from the one being written in does not make them "obtuse." On the other hand to continually insist that no one is helping and that what the original poster is saying is gospel and to not listen to the information givin about the new way dat files are handled in ccleaner, and yet give no further information toward why you think this is not the issue at hand, makes it impossible to help.
The attitude in the following quoted posts will not be tolerated and if it continues I will re-close the thread
Alan
canceled
edit at 21:45 fr :
Not resolved
bahaha.
On top of that, the Original poster is reminded that to create new threads for the same issue and/or to piggy back onto other unreleated threads is incorrect behavior.
Can we please make some movement in this thread.
Thank You,
NdC
I have some sympathy with Exasse as regards Index.dat files. For a start the documentation on Index.dat files does not reflect any new or different action. There's nothing to say that Index.data files are cleaned elsewhere. And there's no specific list of what Index.dat files are cleaned, so it's all guesswork really.
Why is the old Index.dat checkbox still present?
I ran a few tests and found that:
The Index.dat box does nothing on clean
The History box cleans the Index.dat file in history, no more
The Cookies box cleans a few Index.dat files
The Temp Int Files cleans Index.dat in the Temp Int Files folder.
So it seems that you get Index.dat's cleaned in History and Temp Int Files. I'm not going to install an old version of CC to see what that did, but I have a feeling that it cleaned more than that.
Maybe if the Index.dat box is removed then the cleaning would be more as it is described: History for History, Cookies for Cookies, and TIF for TIF.
A new user coming to CC would be fine: the old users who remember the Index.dat box are confused.
v3.01.1327 (25 Nov 2010)- Improved application startup time and INI loading speeds.
- Removed need to reboot for Index.dat cleaning.
- Improved cookie cleaning in Firefox 4.0 Beta 7.
- Improved Chromium based browser detection and cleaning.
- Added support for Adobe Reader 10 and Acronis True Image.
- Improved cleaning for 7-Zip, Adobe Reader 9.0, Microsoft Silverlight Isolated Storage, WinPatrol and Microsoft Management Console.
- Added support for local domains in "Cookies to Keep" list.
- Improved debugging with log file support using /DEBUG command-line parameter.
- Improved detection algorithm for 64-bit and Program Files.
- Improved folder drag and drop in Include options.
- Fixed bug in Uninstall Tool during cancellation.
- Improved drive detection in Drive Wiper screen.
- Added support to refresh cleaning rules using F5.
- Improved translations.
- Minor GUI improvements.
This is the hint in the change of dat cleaning. This brings CCleaner to the point that other dat cleaning program have, where, as I've said, the dats are emptied. The Dats that are not emptied are the ones not locked by the operating system. Those dats are still deleted, some are deleted by the index dats checkmark (I mentioned those above) others are deleted by the new IE history section.
Umm it seems I maybe to blame for the confusion in this thread. It seems I may have accidentally stated "not vacuumed" above, where I meant to say is vacuumed. Please see below with my corrected sentence
