Cleaning AOL
I use AOL with its own browser. How do I clean the cache and history? I see nothing on the CCleaner Windows or Application panes. Any help much appreciated.
Thank you,
John
Welcome John B
If I remember AOL uses IE as its base so selecting the Internet Explorer cleaning options should clean it out.
Welcome John B
I don't know if you have resolved your issue. If you haven't you can try this:
Right click the AOL icon on your task bar.
Click (one click fixes)
In the (clean cache) click (fix it for me)
