In the Applications/Utilities section of the cleaner It shows a program Team Viewer. Since I don't recall seeing this before, I just need to know if that is always an option that can be 'ticked' or does it appear only on PC's that have that program installed? Since I have the other programs in the Utilities section, I assumed that CCleaner lists only those found.
-If so, I never downloaded it and I can't find it via the Search function, in Add/Remove or on the entended list provided with the Revo uninstaller.
Thanks in advance for any help with my Y/N question.
Ah, ten seconds of Google saves ten hours of waiting for a response. If it's this - http://en.wikipedia.org/wiki/TeamViewer - then I'd do everything I could to boot it out.
Team Viewer may not be explained as to how it got on your PC but it is not malware or anything sinister (as I believe that is what @Augeas is hinting at).
I've been using it for years, nice little product.
In itself teamviewer isn't malware, as suggested by @mta, however it is a "remote viewing" software that allows others to monitor your pc's activities, and thus conceivably (while a very slight chance) could be used maliciously if you are unaware of it's source.
