Cleaner: Add Panda AV
Hello,
Thank you so much for CCleaner. A great application.
I recently swithed from Avast AV to Panda Free AV.
Could you please add Panda's Executed process report to the Cleaner's applications.
Best regards.
I also use it and have found this is what CCleaner can clean in it, note that other things like the virus scanning logs you posted a screenshot of are locked by Panda Free Antivirus.
Even disabling the Panda Free Antivirus services will not unlock the ability to clean those using CCleaner, so you have to clean them with Panda Free Antivirus itself by using the 'Clear' button located in: Settings > General > Warnings and Reports
Here's the cleaner for it, doesn't clean much though, and do note if you visit their forum needing help you should disable the below cleaner because they will likely want those logs:
[Panda Free Antivirus (Other Logs)*]
LangSecRef=3024
Detect=HKLM\Software\Panda Security
Default=False
Warning=Note: These are not the virus scanning logs and are completely safe to delete.
FileKey1=%CommonAppData%\Panda Security\Panda Devices Agent\Logs|*.*
FileKey2=%CommonAppData%\Panda Security\Panda Security Protection|*.log
FileKey3=%CommonAppData%\Panda Security\PSLogs|*.log
