Clean setting for attached drives
I have a system with a small hard drive with OS installed only. A second drive via USB that has several backups applied & is used as a repository for my installs.
All of my added installs are directed to the second drive & controlled from the first.
Is it possible to add the option of cleaning additional attached drives using the same settings that are used for the main drive?
I am familiar with the Include/Exclude options. I assume these special "includes" are clean wipes only. Any folder added is completely wiped like free space.
What I would like to do is have other drives wiped with the main drive settings. Add the drive letter & wipe completes 1, 2, 3, etc.
Thanks for all the great software. If you stopped today, it is outstanding work.
