Most programs when they install usually install the help files in as many as 20 different languages, I only need 1. Why not be able to nominate what language you would like to keep & clean out the rest?
Thanks in advance
Thanks in advance
That would be something advanced which really shouldn't be handled by default because some programs (not all) will break when removing their help and lang files, and some will request a repair installation.
To remove such files look into making winapp2.ini entries for your programs. I personally place a lang remove batch file with the installers I download, so whenever I download a new version of a program I can immediately remove the lang and help files I don't need.
