Ishan
Sorry, but I cannot agree with either view
1.
I use the portable version of CCleaner which uses safe CCleaner.ini instead of the Registry minefield
CCleaner.ini holds items such as :-
Include11=PATH|C:\Documents and Settings\Dad\Application Data\Macromedia\Flash Player\|*.*
Include12=FILE|C:\Program Files\LogMeIn\|dbg_LMI_proc.txt
Include11= item obeys your idea, all the Flash Player files and sub-folders are removed, just what I want
Include12= item is different, it ONLY removes the one specified file dbg_LMI_proc.txt, leaving intact 69 other files and 6 subfolders held within ...\LogMeIn\
2.
I see two technical advantages to prefer cleaning before shut-down instead of after start-up :-
a) I like to view the analysis before I execute, and if the analysis has something I was not expecting I have a fair chance of remembering what I did an hour or two earlier and recognise whether I caused the junk, or alternatively decide to suspend execution until further investigation.
If I did the cleaning after start-up I would have to remember what I did the day before. I have a faithful memory that can remember WHAT I did, but WHEN is a little fuzzy.
Where each user has profile that is private from others (unlike Galinkinlin), given "X" user profiles, if each user runs CCleaner before shut-down, then for any user at start-up there should be no junk anywhere. The system is clean, and EVERY profile is clean.
If each user only runs CCleaner after start-up, then all "X" profiles will hold junk, and (along with the system) only the current users profile can be cleaned. There could easily be a GB of ancient junk stuck in the Firefox caches of many user profiles.
3.
I see a massive benefit in cleaning at shut-down,
but it is so important I consider it needs a separate thread (or new forum).
Look out for an up-coming topic "Protect against Unexpected Update disasters".
Regards
Alan
