I understand I can make a script to clean and then shutdown the computer with the following...
CCleaner64.exe /AUTO /SHUTDOWN
However I am unable to make a script to clean and reboot. I thought it would have been ...
CCleaner64.exe /AUTO /SHUTDOWN /R
But the above doesn't work. I have tried other options but nothing seems to restart my computer. I can restart if I type SHUTDOWN /R directly into command prompt but not if using ccleaner first.
I am very sorry I didn't notice your post until now, thank you for your help and reply. I had managed to work it out but it is good of you to post to show others.
