Ever since I updated to Chrome 24, every time I use CCleaner to clean the cache and cookies, the Chrome settings will reset itself back to default. This NEVER happened until the Chrome update.
Which Chrome settings? All of them?
OS version?
CCleaner version?
All of the Chrome settings.
Windows 7.
CCleaner version 3.27.1900(64-bit)
I forgot to mention that all of my extensions get deleted too.
Hate to double post, but is nobody looking into this?
Management reviews the bug reports, which is the purpose for maintaining a forum. Including details in your post helps them replicate the issue and write a code fix.
Happening to me as we'll. I even tried to reinstall cleaner v26 but while successful the problem still exists. All google chrome reset to defaults. Hope management can fix this bug
where is your chrome profile located. Most people aren't experiencing this, as far as I can tell it is limited to the two of you.
please run analysis
view details
right click and save results to text
post text file to this thread
I don't sign in with a Google profile if that's what you mean by asking where my chrome profile is located, and I have never signed in to one before this problem.
Here's the details:
ANALYSIS COMPLETE - (19.490 secs)
376 MB to be removed. (Approximate size)
~Large amount of text removed by moderator and inserted into a text file instead
After carefully reviewing this situation I now believe that the problem is not with ccleaner but with the settings in google chrome and I am able to reproduce the same...Sorry for the confusion....
Downloaded the latest version of CCleaner and the problem is fixed. Thanks a whole bunch!
