PC registered for cleaner is broken
and cant deregister to change to alternative PC
Just download an installer from here and put CCleaner Free on your new machine: Download CCleaner builds | CCleaner Portable, Slim, and more
Double clck the downloaded file to install CCleaner, open it, and in Settings > My subcription enter your existing licence key to activate it as Pro.
Obviously people do get new machines so itās as simple as that.
As long as you are not using the key long-term on more devices than your subscription is valid for then there is no problem.
Afraid that doesnāt work as cleaner thinks original
PC is operative so new copy of cleaner will not recognise
It. Version I have is for one outlet only and will
Not accept system key
It does work, I have swapped CCleaner licence keys between machines many, many, times using exactly that method.
Other users have done the same.
It does not matter if you already have single PC CCleaner licence active on a machine - you can still use the same licence key to activate CCleaner on another machine.
(You just canāt use a key long term on more machines than it is valid for).
There is no need to āderegisterā a CCleaner licence key; in fact there isnāt any way that you could āderegisterā one (other than uninstalling CCleaner).
If it is not letting you activate CCleaner with that key then there must be another reason.
By far the most usual reason for a key not being accepted is that the user is typing it in wrongly.
Double chack that you are not putting āBā instead of ā8ā, or āSā instead of ā5ā etc.
(Iāve done it myself in the past when I was typing in exactly what I had written down, but I had written it down wrong).
You can lookup your key by putting the email that you used when puechasing it in here: CCleaner.com - License Lookup
If that isnāt showing you a key then is the key you have still valid or has it passed itās expiry date?
Check if your subscription tis current here: Subscription Management
Are you seeing an error message when you type your key into CCleaner?
What exactly does it say? The wording can indicate what the problem may be.
Can you post a screenshot of it?
