I have windows 10, latest version available form microsoft Home user, version 1803, 17134.12
using reinstalled latest version of CCleaner. 544.162.6575
I re-installed because when I click to start Ccleaner and press "run ccleaner" it stops. It disappears from the task manager. I have scanned for viruses, restarted the PC and can't get Ccleaner to work. Problem began 12 hours ago, I have slept since then.
Do you have MalwareBytes premium installed or a trial of the same?
One of the settings seems to have an adverse affect on several programs including CCleaner.
I dont have malwarebytes. I have changed nothing on my system, I dont think there has been an auto update of Windows this week. 24 hours ago it worked fine.
14 minutes ago, arcobelina said:
What antivirus are you running then ![:) :)]()
I use Kaspersky anti virus. I have lodged a support ticket with them to see if they have blocked Ccleaner to try and push people towards their cleaner.
See the linked comments in this
Thank you Nergal. fixed it goodonya
