CCleanerPro and Defraggler
I upgraded to CCleanerPro. Is Defraggler included in it. If so, must I reinstall Defraggler using the license key for the upgraded CCleanerPro version? I believe that Defraggler was included in my CCleaner before the upgrade.
Defraggler has gone totally free and is no longer sold as Pro.
There is now no difference at all between Free and Pro; apart from what it says at the top.
PS. That’s why it is no longer included in the CCleaner Premium bundle.
Simply download, install, and use it.
If you are having problems with downloading from that page (there have been some reports) then you can download it from the builds page:
Note that if you go to the Help>About in defraggler it still has the “Upgrade to Pro” button.
However the fields for entering a licence are for the ‘Old Style’ keys - it’s just a leftover that has not been removed.
If you do click on the ‘Purchase’ button there then you are taken to an invalid webpage - because Defraggler is now totally free.
