Hi !
I installed CCleaner 5.09.5343 on my pc with XP Professional.
Just start the CCcleaner the PC restarts.
The HD has just been formatted.
My PC is equipped with a AMD Athlon II X3 450 and 4GB Ram.
Thanks for your help
Hi !
Did you get Ccleaner from here ?
https://www.piriform.com/ccleaner/builds
How many service packs do you have with XP?
1) Yes
2) SP 2
Please see here
http://forum.piriform.com/index.php?showtopic=43027&p=260079
Can you not install SP3?
Manifests that are created by Visual Studio 2005 can exhibit this behavior. However, this feature is intended to modify only the behavior that this article describes.Therefore, if the system is not severely affected by the lack of this feature, we recommend that you wait for the next software update that contains this feature.
like the OP i have winXP with SP2. when i run ccleaner 5.03 i get BSOD. i went back to 5.02 with no issues.
probably seems ultimately a problem of Ccleaner programming to be ...
Please realize that hazelnut pointed to the hotfix from Microsoft, thus it's a (dead version of) Windows issue and not ccleaner
Hi !
I installed CCleaner 5.02.5101 and the PC does not restart more.
I tried CCleaner 5.09 / 5.08 / 5.07 / 5.06 / 5.05 / 5.04 / 5.03, but the PC was restarted more
Thank you all for the help
Antonio
You need this hotfix from Microsoft if you only have SP2 with XP
mrt gives me indirectly right
from hazelnuts link from older thread with xp sp2 issue:
We have applied this patch to our testing machine and problem was fixed. No more BSOD after installing it.
We are working on a solution to avoid this problem, but in the meantime, you might want to consider this hotfix...
and this is directly from microsofts hotfix-description:
it is a ccleaner problem,
means there is a change in ccv503 that canceled the support for xp sp2...that is not in ccv502. be it intended or not.
but you have right --> xp with sp2 is out of date and no longer supported for quite some time and sp3 too from microsoft.
--> with this context its alright that piriform also no longer supported xp sp2 and makes no changes for this and support only for sp3.
Hi !
I installed KB-943232 and Ccleaner 509 works perfectly.
Thank
Hi !
Thank
Thank you Tonio for the feedback
Stickied
And title edited
