Ccleaner wont delete empty folders in recycle bin
hello,
im usually deleting from time to time the empty folders like Public (Users/Public) or the folders like Videos, Pictures, Documents, Favourites,etc (Users/User/Favourites,etc.). Im sorry if I spelled a folder name wrong but mine are in german so ya ^^
So after I click analyze and run Cleaner I make the Recycle Bin folder visible and I click on the properties of it and it says that it got like six or more empty folders inside. Do I look inside the recycle bin I find no folders at all. So I delete the recycle bin so the folders get deleted. May you fix this bug please? It would be really nice :)
p.s. Folders that I cr8 by myself (empty ones) and delete them with Ccleaner are working fine strangely.
What operating system are you using?
Perhaps you have a corrupt recycle bin....
http://www.vistax64.com/tutorials/131294-recycle-bin-corrupted-cannot-delete-file-folder.html
