ccleaner wont clean session
It tried updating a few times which it said the update contained the fix for this problem. But it doesn't work. currently running windows 10, with ccleaner pro v5.55.7108. I believe thewindows 10 version maybe a dell product and it doesn't contain the files associated with the solutions available on line in the Microsoft info. Help
I've moved this to ccleaner bugs. But you need to provide a bit more information.
Which session are you talking about (chrome? Edge? Firefox? Something else?)?
What happens when you try to clean it (says skipped? Say it removed it but it's still there?)?
edge 10. It say session could not be cleaned. then when you clicked on more it took you to Microsoft page referring to start up files and remedy , but according to my son my version of 10 it doesn't have these files to manipulate to correct this condition. I have a dell comp running there version of software.
Is the issue perhaps where CCleaner shows a popup/notification instructing to modifying the system to allow it to properly clean Edge in Windows 10 Home v1809 (October 2018 Update)?
If it is, and if you visited that Piriform/CCleaner webpage telling you to edit the registry well the information is incorrect because that registry data does not exist. Instead that registry data has to be created via instructions such as this:
https://forum.piriform.com/topic/53177-how-to-disable-pre-launching-and-pre-loading-so-ccleaner-can-fully-clean-edge/?do=findComment&comment=302353
Well tried to insert proper info into edge and the program would not except it. It just disappeared.
On 3/20/2019 at 19:21, Nergal said:
To reiterate what Nergal already stated in the above quote again. If you want help provide more info, nobody can guess what you're asking otherwise.
Went to the link provided in Andavaris previous post and followed the instruction as per, The info would not load in edge 44.17763.10, html 18.17763.Am I the only one having this problem. I have ATT for ISP using a Dell version of Windows 10
Edge loads the link without issue on my laptop using Windows 10 v1803.
Is member trying to install Andavari's instructions into Edge itself instead of the registry?
No we were putting it in the registry.
I was having the same pop up telling me it could not clean Edge Sessions....Firefox is my default browser and I don't use Edge...I clicked on the Edge icon and it's home page opened up...I clicked it off and ran CCleaner...it cleaned Edge Sessions...and shows cleaning Edge Sessions ever since...I guess Edge is running in the background...I'm not a computer "expert" but the pop up does not come on anymore
