Ccleaner wipes Bypass Paywalls settings
I'm using Firefox with the Bypass Paywalls add-on. I have noticed with the most recent Ccleaner version my Bypass Paywalls settings are being wiped - the full list of selected news websites is left unchecked.
Are there any settings in Ccleaner I can tweak so the settings aren't wiped? Or is this a problem with the add-on that will have to be rectified by developer?
Any help would be much appreciated.
In case it is relevant
https://community.ccleaner.com/topic/58613-problem-with-firefox-79/?tab=comments#comment-322140
Thank you - I followed the advice from APMichael here and it has seemed to solve the issue.
34 minutes ago, barryc808 said:
		Thank you - I followed the advice from APMichael <a href="<___base_url___>/topic/58613-problem-with-firefox-79/?do=findComment&amp;comment=322202" rel="">here</a> and it has seemed to solve the issue.
Glad to hear you are sorted now :)
