Ccleaner Versions
I use free version of CCleaner and up-date each time I am informed of a new version.However I notice that in my downloads there are versions showing "ccsetup314(1) althe way through to "ccsetup326"Does this mean that the old version is not automatically deleted?If so can I delete all the old versions?
The installer doesn't get deleted after you run it, you must remove the installer yourself.
