CCleaner v5.22.5724 won't run Cleaner
Just downloaded update to v5.22.5724. Now CCleaner won't run Cleaner. Other functions seem okay.
Help, please. Any suggestions?
What operating system are you using?
Was Ccleaner already installed and you are installing the new version over the top?
Explain what happens when you try to run it.
Are you saying other functions within Ccleaner are working, it is just the cleaner bit that isn't ?
