When you double click the "run cleaner" button after you have already clicked it (because I have spastic fingers), the window pane in the middle of the program jumps to the right. Not really a problem just more like a small nuisance.
Hi, and welcome to the forums .
This issue has been raised before but the devs haven't replied about it.
I am running CCleaner 2.35.
I tried to reproduce it, but my computer must be too fast. It cleaned it in 0.107 (1/10 of a second).
I did not see any problems, but I guess it did not take long enough to clean to find a problem.
Anyone else that can verify?
Thanks for the info!
Type for /l %i in (1,1,1000) do fsutil file createnew %temp%\%i 1 into a command prompt, uncheck the "Only delete temp files older than 24 hours" checkbox in CCleaner's Options >> Advanced, and clean. This should give you enough time to double-click the Run Cleaner button (it will create a thousand of 1-byte files in your Temp folder).
