Ccleaner v.3.25 whit winapp2.ini v3.25.121212 Problem!?
Please Help !
http://www.youtube.com/watch?v=KIL3FhjKO7M&feature=youtu.be
What i can do it !?
snapback.pngCompare, on 18 December 2012 - 03:13 PM, said:
What i can do it !?
First, desist from double posts.
Second, remove WinApp2.ini and try again.
Then do NOT continue in this topic but continue with the topic you started at
http://forum.pirifor...showtopic=37449
http://forum.piriform.com/index.php?showtopic=32310&st=2560
Download
Ccleaner v.3.25 Prtable and install
Download
winapp2.ini v3.25.121212 and istall the same Problem!
Using the Portable is a good step.
Please clarify.
Does this only occur when WinApp2.ini is added ?
yes it is, only white winapp2!
As your question is in the Winapp2.ini thread, I'll close this one.
http://forum.pirifor...560#entry226800
EDIT:
Just to clarify, as winapp2.ini is a user compiled add on, any issues with it can't really be described as CCleaner bugs, hence the suggestion to respond to the same question already in the winapp2.ini thread.
Apologies for curtailing your help in this one Alan, but this hopefully prevents others with similar issues raising them as CCleaner bugs. :)
