Premke
1
Hi all of you ccleaner users,i hope that you can help me.
I have 3 accounts on my computer and administrator on which i have instaled
newest CCleaner.
Maybe this is mentioned,is there options so i can enable CCleaner for all
computer users (so i dont need to install on any particular) and if it isn't
than that will be my suggestion.
Thanks in advance
tomn
2
Once CCleaner is installed on a computer it will work for multiple user profiles. But....
Unless I am misunderstanding you, CCleaner will only clean the profile of the user who is logged in at the time.
I have two user profiles on my computer and it will only clean junk from user who is logged in at the time.
I found this link, maybe this will be helpful: http://forum.piriform.com/index.php?showtopic=14936
