CCleaner Unattended installation
Hello there,
I'm curently trying to install CCleaner by deployment at our client, only one problem with it, i cannot disable the monitoring from installation, i have to open CCleaner every time to disable this.
is there a statement when installing (I'm currently using: setup.exe /S) where i can disable this function?
Joost
Hi joost :)
As you are using Ccleaner in a client type situation I assume you must have the paid version.
In that instance you are entitled to support from Piriform directly.
http://www.piriform.com/support
(scroll down that page a bit)
:wacko: i have not read about deactivating the monitoring option in command-line-parameters.
the "normal" install-mode without command-line-parameter you do want not to take? there CCleaner remembers your last settings, even the one not desired by you...
or just have these 2 lines in your .ini file when you deploy.
Monitoring=0
SystemMonitoring=0
Hi all please wait to see if eindprojectnbc confirms they're using the correct version for distribution to clients via deployment
