Morning, love the product first off.
When I have Monitoring turn on (and love what it does) works great, I know you have a Scheduled Event to by-pass the UAC when logging on the pc..
But if you log in through RDP from a clean boot.. the UAC will appear everytime asking is it OK to run CCleaner.
This is a mirror issue. but can you correct the Scheduled Task to work via RDP also, not just local log on.
Thank Jerry
Thank Jerry
Actually, just from your description, it sounds like Microsoft forbids the command line extra arg0 which allows a program (any program) run as administrator without asking. For security reasons alone this is a good thing otherwise a malicious remote actor could execute root level access after a simple exploit of the task scheduler to create arg0 tasks. Sadly the only way to skipuac is via arg0
That said you could test my theory (I no longer have a computer I can remote into to test myself) by running ccleaner64.exe from commandline with the arg0 extra remotely. And see if it runs
