Hello,
Why do i have 2 ways to launch CCleaner from the trashbin icon ?
I have in my french Desktop :
Under "Corbeille" Icon (see attached image) :
Executer CCleaner
Lancer CCleaner
What is the difference between these 2 menu options ?
Regards
Hello,
Executer CCleaner
Lancer CCleaner
Regards
Hi Didou, and welcome to Piriform.
One option runs CCleaner, and the other simply opens CCleaners GUI for access.
False,
"Ouvrir CCleaner..." open the GUI,
But the 2 others menu options. ("Lancer CCleaner" and" "Executer" CCleaner")
Did you really seen the initial screenshot i've sent ?
There fore this bad behavior has gone with the last release 2.25.1025 (that was a mistake as well)
Thank's for your answer.
Yes I did see your screenshot, and as with all other CCleaner problems I encounter, I tried to reproduce what you show in that screenshot.
Whatever I select as an option, I can only get two CCleaner choices in the context menu, the two I explained above,
And your question was:
Which I believe I answered.
Yes but his screen shows 3 * CCleaner entries.
In all English installs I've ever done, there are only 2 options
Open and Run,
He has "Executer CCleaner", "Lancer CCleaner" and "Ouvrir CCLeaner" which is 3.
No idea why tho'.
Yes, I did notice that, but like you I can't reproduce it, so replied with what I could reproduce.
