CCleaner Top Shelf
Just wanted to add my nickels worth about CCleaner.
Top-Shelf Material in the cleaning dept.Fast , Easy and completes the clean with no problems.
Yupe...CCleaner Is A High Quality Stuff...
quite true...
However I can't understand the need to put "Open CCleaner" and "Run CCleaner " when you Right Click on the Recycle Bin Icon? Especially when you can set the Recycle Bin to empty when Shut Down.
this setting allow you to run CCleaner without having to launch CCleaner...
OK , Nice little add-on ...... , Allows to run in background.....
