Hello all
I do not know English more than
ccleaner add please
x86
temp folders "C:\Documents and Settings\userName\Local Settings\Temp"
c:\windows\temp
C:\WINDOWS\Prefetch
Hello all
ccleaner add please
x86
c:\windows\temp
C:\WINDOWS\Prefetch
Some of what you want it already built into CCleaner, see:
C:\Windows\Prefetch is not a temp folder and should not be cleaned.
Hello all
ccleaner add please
x86
c:\windows\temp
C:\WINDOWS\Prefetch
Temp folder is built into CCleaner. If you want total cleaning of that folder, just go into CCleaner settings & uncheck "Don't delete files older than 24 hours".
This will let CCleaner erase it all.
Prefetch is sort of supported, where it can remove old entries. I haven't tried adding Prefetch as a folder to clean to see how it does. I suppose you can use WinRar to create a self extractor version where after running CCleaner, it will silently run a command to delete the files in that folder. For icons, you can use Batch Icon Extractor (free & the best quality icons extraction I tried so far).
http://www.filehippo.com/download_winrar
http://www.rw-designer.com/batch-icon-extractor
If you do a little googling & experimentation, you can find the proper del commands to empty a folder of the contents. Just be careful, be sure you have a backup before beginning, & have fun!
