I have been using computers since the "Pegasus Autocode" {!) and ccleaner for years, and never had a problem until the last two releases. I am presently running a tower, laptop and Lenovo MIIX 310 notebook, all running win10 and, all with ccleaner. The tower and laptop run ccleaner fine but ccleaner on the Lenovo sticks at 3%. I have uninstalled then reinstalled and the first run was fine but after that it reverts to sticking at 3%. Cancel doesn't work and I end up closing it from the task master. Anyone got any ideas?
what area does it say it's cleaning at the 3% stage?
Is it IE or Edge?
have you tried running CC with the PC in Safe Mode?
3% is internet explorer history. Haven't tried to run it in safe mode yet. I shall try that later today and let you know. Thanks.
and you use IE on all 3 PC's?
if Safe Mode doesn't help, then go into IE and clean its history from its own mechanism: Tools, Internet Options, General tab, in the Browsing history area, click the Delete button, tick appropriate box and hit Delete.
Works in safe mode.
And it is now running fine after a restart. Thank you.
Hi guys. Yes, I also got CCleaner cleaning cycle stuck at 3%. Re-booting the PC also did the trick for me. Many thanks.
