CCleaner still missing from recycle bin
Good morning, CC cleaner has been missing since the update from the contextual menu of the Recycle bin. I use this almost daily and now it is gone, please bring it back as I hope this is a bug and not something that was purposely removed.
Not a bug. They decided to not have it as a right click option (no idea why)
You will have to use the Ideas Portal to suggest it.
Roger, where is the “ideas portal”?
Left hand menu of main ccleaner page.
I think I may have a different web version the. I don’t have a left hand menu.
Open your CCleaner program and look at the bottom of the left hand side.
See here
LOL, holy crap! It is way too early in the morning! Thank you very much! found it!
This has been added to 7.6. update for right click goodness
This usually happens after an update resets the shell integration.
Try this:
  • Open CCleaner → Options > Settings
  • Make sure “Add ‘Run CCleaner’ to Recycle Bin context menu” is enabled
  • If it’s already enabled, toggle it off → restart PC → turn it back on
If still missing, reinstall CCleaner (run installer as admin). That normally restores the right-click option
