Ccleaner Skipping Edge in v.10240 Win10 Pro x64
First let me say that although I have not been here, I am a long time Ccleaner user and fan.
I am proud to be a Ccleaner Professional Edition user. Piriform RoCkS !
Ok enough of that....
I recently noticed that Ccleaner is "Skipping Edge when cleaning, and when it is closed and Ccleaner preforms a auto clean.
I thought at first that Edge was not fully closing so I took a peek in Task manager and it was stopped and to double check I checked it in Process Lasso as well and sure enough it was closed.
Confused I started digging in my "Exclusion" list and it was not listed as an excluded file or folder.
I can solve most issues with a little common sense and previous experience, but this escapes me.
I thought of uninstalling Ccleaner and re-installing clean, but before I do that I wanted to post here and see what you guys think or if anyone else has experienced this. PeAcE
OS: Windows 10 Pro x64 (10240)
Ccleaner: v.5085308
Never mind, I will take the uninstall route I guess. PeAcE
Read some of the other threads it's being worked on, and is only happening to some people. Do you have any windows-ui apps running? While trying to clean?
No, thats the first thought I had and made sure with process lasso.
I did some trouble shooting before dropping in here (as a last resort) to pester you folks.
I have uninstalled it for now, but will reinstall once I have more time to monitor it.
Thanks
