CCleaner settings
Running CCleaner erases my Internet Explorer preferred browser and substitutes "blank" Which cleaner boxes should I uncheck to prevent this happening?
Nothing in ccleaner should remove default browser (especially ie) or reset your homepage (especially to blank). Did you get ccleaner from the piriform site or from filehippo? If not where did you get it from? Did you only run the cleanup section? Or did you also run the registry (or any other sections). Please also list your OS version and ccleaner version number
