CCleaner Settings save + restore
Is there a way to backup CCleaner's settings so they can be restored later if required. I'm particularly thinking about the cookies list - I'd rather not have to recreate the 40+ cookies I've added over the last few weeks.
Hello David,
Open ccleaner and on the left is the options button, press and click on cookies. There you will be able to save your important ones such as ccleaner forum!!
I maybe wrong but i think he wants to actually backup the settings of Ccleaner including the cookies he has already set to keep. If im correct
Click "Run" in the start menu and type regedit and browse to the below registry entire
HKEY_CURRENT_USER\Software\VB and VBA Program Settings\CCleaner
once there right click on CCleaner and click export and choose where you want to save it(preferably either a external backup or a non Windows HD )then call it something like Ccleaner backup and click save. If you have any problems with Ccleaner and or your PC and have to reinstall simply install Ccleaner and double click the registry entire you backed up(make sure Ccleaner is close first).
hazelnut - thanks, but I meant what englishmen said.
englishmen - perfect. Thank you. :) P.S. Your sig http://home.cogeco.ca/~raduking/ is 404.
P.P.S. MrG - this would make a nice feature if provided as an export / import option within CCleaner.
Thanks David i noticed the official RK Launcher site was down. I found on the Aqua forums they now have a mirror up, i have relinked my sig, thanks.
