Hi,
I have used ccleaner on loads of machines but today it caused me a problem, after it ran windows seems unable to display some images for example
the google home page logo now doesnt show
when nortons is open its background image is missing
all website backgrounds have gone
but i get not one red x to say the image is actualy missing
even the little drop down arrow on the address bar has gone
Please help
ps i didnt run registry ceaner till after problem happened
Can you give more info such as what operating system you are using.
What security software you have, and if it is all up to date and scans are clean.
Do you have system restore turned on?
Any other problems you have noticed?
Surprised that you did a registry clean after finding problems with your icons etc ![:huh:]()
hi,
Its running windows xp home sp3, i removed norton thinking it may have been blocking images thinking it was ads or something.
I ran malwearbytes and nothing was found.
I dont see anyother problems
system restore is turned on but only just now and it wont resotre back to the last and only one it has stored ![:(]()
ok think i fixed it, running ccleaner for some reason changed a setting in accesibilty options, i turned all the crap off in there and there ys go woohoo
it was the high contrast option
Glad you are sorted and for posting back. Your find might help someone else, you never know!
This could have been triggered by 5 rapid presses of the shift key (also known as "Sticky Keys").
High contrast option is under Display tab.
Glad you got it fixed!
